Author
Matrix Ltd
Version
1.6
Category
Graphical Color
GLCD (SSD1331) component
Graphical display component based on the SSD1331 colour graphical controller IC.
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
ControlContrast
ControlContrast
Sets the display contrast from 0 to 255.
- BYTE
Contrast
Range 0 - 255, Default 207
ControlDisplay
ControlDisplay
Allows the display to be switched on and off
- BYTE
Control
0=Off, 1=On
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
InvertDisplay
InvertDisplay
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
Range: 0-255
- BYTE
Green
Range: 0-255
- BYTE
Blue
Range: 0-255
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
Range: 0-255
- BYTE
Green
Range: 0-255
- BYTE
Blue
Range: 0-255
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
DC
Data/Command pin used to inform the display if data or commands are being sent.
Toggle CS Pin
Defines if the CS pin is left in the enabled state to speed up display operations. Yes: Toggle the CS pin, other devices with their own CS pin can use the SPI bus. No: Activate the CS pin and leave it that way, faster but less flexible.
CS
Chip select pin used to activate the SPI bus on the display ready to receive commands. Allows multiple devices each with their own unique CS pin to be sat on the same SPI bus.
Use Reset
Decides if the reset pin is driven using an I/O pin. If not driven from a pin then you simply need to connect the reset line to VCC to enable the display.
Reset
Reset pin used to reset the display as part of the initialise function.
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1331.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1331.fcfx
