Component: Robot Arm v2 (AllCode)
(Redirected from Component: ID 76e989d0 a2ed 457f a293 3025b804f433)
Version | 1.0 |
Category | AllCode |
- 1 Robot Arm v2 component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DisableMotors
- 5.2 GetAPI
- 5.3 GetAngles
- 5.4 GetColourSensor
- 5.5 GetPLCInputs
- 5.6 GetPosition
- 5.7 GetWifiIP
- 5.8 GetXYZ
- 5.9 GotoPosition
- 5.10 HomeAll
- 5.11 HomeAxis
- 5.12 Initialise
- 5.13 IsMoving
- 5.14 ResetToBoot
- 5.15 SetAngle
- 5.16 SetAngles
- 5.17 SetBluetoothMode
- 5.18 SetBluetoothName
- 5.19 SetBluetoothPin
- 5.20 SetCalibrationLengths
- 5.21 SetCalibrationPosition
- 5.22 SetCalibrationRadius
- 5.23 SetCanId
- 5.24 SetCanMode
- 5.25 SetGripper
- 5.26 SetMotor
- 5.27 SetMotors
- 5.28 SetMovementSpeed
- 5.29 SetRelay
- 5.30 SetWIFIPassword
- 5.31 SetWIFIPort
- 5.32 SetWifiMode
- 5.33 SetWifiSSID
- 5.34 SetXYZ
- 5.35 StoreAngles
- 5.36 StoreCurrentPosition
- 5.37 StoreMotors
- 5.38 WhileMoving
- 6 Property reference
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here to download the component source project: FC_Comp_Source_RA2_ComponentSource.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_RA2_ComponentSource.fcsx
DisableMotors
DisableMotors | |
Disables all motors | |
- VOID | Return |
GetAPI
GetAPI | |
Gets the API version number | |
- BYTE | Return |
GetAngles
GetAngles | |
Collects the current joint angles of the motors. | |
- FLOAT | Angles |
Float Array To Hold the step position return values | |
- VOID | Return |
GetColourSensor
GetColourSensor | |
Samples and returns the RGB values read by the colour sensor | |
- BYTE | RGB |
Byte Array To Hold the RGB sensor values | |
- VOID | Return |
GetPLCInputs
GetPLCInputs | |
Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch. | |
- BYTE | Return |
GetPosition
GetPosition | |
Collects the current step positions of the motors. | |
- UINT | Positions |
UINT Array To Hold the step position return values | |
- VOID | Return |
GetWifiIP
GetWifiIP | |
Collects the IP address of the robot arm WIFI connection. | |
- STRING | Return |
GetXYZ
GetXYZ | |
Collects the current XYZ position of the end tool. | |
- INT | XYZ |
INT Array To Hold the X, Y and Z return values | |
- VOID | Return |
GotoPosition
HomeAll
HomeAll | |
Function to automatically home all motors. Macro blocks until complete. | |
- VOID | Return |
HomeAxis
HomeAxis | |
Function to automatically home a specific motor. Macro blocks until complete. | |
- BYTE | Axis |
0=A, 1=B, 2=C | |
- VOID | Return |
Initialise | |
- BOOL | Return |
IsMoving
IsMoving | |
Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit. | |
- BOOL | Return |
ResetToBoot
ResetToBoot | |
Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro, | |
- VOID | Return |
SetAngle
SetAngle | |
Sets the angle of a single motor | |
- BYTE | Motor |
0=A, 1=B, 2=C | |
- FLOAT | Angle |
Range 0.0 to 359.0 | |
- VOID | Return |
SetAngles
SetAngles | |
Sets the angle of all motors | |
- FLOAT | AngleA |
- FLOAT | AngleB |
- FLOAT | AngleC |
- VOID | Return |
SetBluetoothMode
SetBluetoothMode | |
Configures the Bluetooth mode. | |
- BOOL | Mode |
0=Disabled, 1=Enabled | |
- VOID | Return |
SetBluetoothName
SetBluetoothPin
SetCalibrationLengths | |
Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates | |
- FLOAT | LengthA |
- FLOAT | LengthD |
- VOID | Return |
SetCalibrationRadius | |
- FLOAT | Radius |
- VOID | Return |
SetCanId
SetCanId | |
Stores the specified CAN ID into an internal none volatile memory location. | |
- UINT | ID |
- VOID | Return |
SetCanMode
SetCanMode | |
Configures the CAN mode. | |
- BOOL | Mode |
- VOID | Return |
SetGripper
SetGripper | |
Sets the new position of the gripper | |
- BYTE | Position |
0 = Closed, 255 = Fully Open | |
- VOID | Return |
SetMotor
SetMotor | |
Sets the step position of a single motor | |
- BYTE | Motor |
0=A, 1=B, 2=C | |
- UINT | Position |
- VOID | Return |
SetMotors
SetMotors | |
Sets the step position of all motors | |
- UINT | PositionA |
- UINT | PositionB |
- UINT | PositionC |
- VOID | Return |
SetMovementSpeed
SetMovementSpeed | |
Controls the movement speed of the arm and the ramping increment | |
- UINT | Speed |
Range 0-10000 default 8000 | |
- UINT | Increment |
Range 0 to 5000, default 50 | |
- VOID | Return |
SetRelay
SetRelay | |
Allows the vacuum relay to be switched on and off. | |
- BOOL | State |
- VOID | Return |
SetWIFIPassword
SetWIFIPort
SetWIFIPort | |
Sets the WIFI port number | |
- UINT | Port |
Default 1245 | |
- VOID | Return |
SetWifiMode
SetWifiSSID
SetXYZ
SetXYZ | |
Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0. | |
- INT | X |
- INT | Y |
- INT | Z |
- BOOL | Return |
StoreAngles
StoreCurrentPosition | |
Stores the current position into an internal none volatile memory location. | |
- BYTE | PositionIndex |
Range: 0 to 40 | |
- VOID | Return |
StoreMotors
StoreMotors | |
Stores the specified step position into an internal none volatile memory location. | |
Range: 0 to 40 | |
- VOID | Return |
WhileMoving
