Component: Keypad (BL0138) (E-blocks 2)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | E-blocks 2 |
Keypad (BL0138) component
Keypad component to drive the E-blocks 2 BL0138 Keypad board. Provides twelve individual raster scanned switches.
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed.
The index of the key that was pressed is passed back to the user.
GetAscii
Gets the ASCII value for the current keypress.
If no key is pressed then the macro returns the value 255.
GetString
Gets the ASCII value for the current keypress and returns in the form of a string.
If no key pressed then the macro returns a null string.
GetNumber
Gets the numeric value for the current keypress.
If no key pressed then the macro returns the value 255.
GetIndex
Gets the index value for the current keypress.
WaitReleased
Blocking call that waits for the keys on the keypad to be released.
If no key is pressed then the function will return immediatley.
Simulation macro reference
Connection Type
This property is of type Fixed list of ints and can be referenced with the variable name ConnType.
Port
This property is of type Digital port byte and can be referenced with the variable name Port.
