Component: WLAN Dummy (EB069, ESP8266) (ESP8266) (Wireless)
Author Matrix Ltd.
Version 2.0
Category Wireless
WLAN Dummy (EB069, ESP8266) component
Wireless LAN component designed to work with the ESP8266 module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP8266_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP8266_Dummy.fcfx
The examples below are all done using a EB091 board as the host
The EB069 ESP8266 Wifi E-block is connected to PORTD 0-7 with the patch setting set to B.
The EB005 LCD E-block is connected to PORTB 0-7 with the patch setting set to Default.
Other host boards are compatible with the examples, simply change the target chip and component connection properties.
Firmware Test
This example collects the firmware version from the ESP8266 module and displays it on an LCD. Tested working with firmware version 00150900.
FC6 Icon.png FirmwareTest
Wireless Scanner
This example scans for wireless networks in range and prints the network IDs to the LCD along with the signal strength and security type.
FC6 Icon.png WifiScan
Creating An Access Point
This example creates an access point you can connect your phone or laptop to named Flowcode_ESP8266. The password to connect to the access point is flowcode6.
Note this example simply creates an access point, no data is transferred.
FC6 Icon.png CreateAP
Joining An Access Point
This example joins an existing access point. The network ID and Password must be altered to match your local WIFI network settings.
Note this example simply joins an access point, no data is transferred.
FC6 Icon.png JoinAP
TCP Client
Once joined to the network the example connects to the MatrixTSL website and requests a file which is printed out on the LCD.
FC6 Icon.png TCPClient
TCP Server
Once the access point is created the example shows the server IP address on the LCD. Connecting to the wireless network on your phone or laptop and visiting the IP address shown on the LCD using a web browser allows you to switch LED outputs on and off.
FC6 Icon.png TCPServer
Network Comms
Here are some examples using the Network Communication component linked to the ESP8266 component.
FC6 Icon.png NetworkComms ESP8266 Client
FC6 Icon.png NetworkComms ESP8266 Webserver
CheckForPageRequests
Fc9-comp-macro.png CheckForPageRequests
CheckTCPServerIP
Fc9-comp-macro.png CheckTCPServerIP
Collects the local IP address of the active TCP server.
ClientConnect
Fc9-comp-macro.png ClientConnect
Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
Fc9-u8-icon.png - BYTE Type
0 = TCP, 1 = UDP
Fc9-string-icon.png - STRING IPAddress
e.g. "192.168.1.20"
Fc9-u16-icon.png - UINT Port
Remote port number to connect to, HTTP comms = Port 80
ClientSendArray
Fc9-comp-macro.png ClientSendArray
Fc9-u8-icon.png - BYTE Data
Fc9-u16-icon.png - UINT NumBytes
ClientSendRequest
Fc9-comp-macro.png ClientSendRequest
Sends out a request for data
Fc9-string-icon.png - STRING Request
e.g. "GET / HTTP/1.0\r\n\r\n"
ConnectToSSID
Fc9-comp-macro.png ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
Fc9-string-icon.png - STRING SSID
Fc9-string-icon.png - STRING Key
Fc9-u8-icon.png - BYTE Timeout
Number of seconds to wait for the connection, default 2
ControlTCPServer
Fc9-comp-macro.png ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
Fc9-u8-icon.png - BYTE Enable
0 = Stop Server, 1 = Start Server
Server port to listen for incoming TCP/IP data requests
CreateAccessPoint
Fc9-comp-macro.png CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
Fc9-string-icon.png - STRING Password
Fc9-u8-icon.png - BYTE Encryption
DisconnectFromSSID
Fc9-comp-macro.png DisconnectFromSSID
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK"
EndServerConnection
Fc9-comp-macro.png EndServerConnection
GetByteWithTimeout
Fc9-comp-macro.png GetByteWithTimeout
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
GetFirmwareVersion
Fc9-comp-macro.png GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
GetInValue
Fc9-comp-macro.png GetInValue
Fc9-u8-icon.png - BYTE index
Index of the request paramter, starting at zero Range 0-2
GetRxArray
Fc9-comp-macro.png GetRxArray
Fc9-u16-icon.png - UINT MaxBytes
Fc9-comp-macro.png Initialise
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module
ReadEncryptionModeFromScan
Fc9-comp-macro.png ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Fc9-u8-icon.png - BYTE Index
SSID Index
ReadSSIDFromScan
Fc9-comp-macro.png ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
SSID Index
ReadSignalStrengthFromScan
Fc9-comp-macro.png ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
SSID Index
Fc9-s16-icon.png - INT Return
ScanForSSID
Fc9-comp-macro.png ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SendString
Fc9-comp-macro.png SendString
Sends the given Text. Appends a CR to the end of the string it SendCR is greater than 0.
Fc9-u8-icon.png - BYTE SendCR
Send_Embedded_HTML_Page1
Fc9-comp-macro.png Send_Embedded_HTML_Page1
Send_Embedded_HTML_Page2
Fc9-comp-macro.png Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page3
Fc9-comp-macro.png Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page4
Fc9-comp-macro.png Send_Embedded_HTML_Page4
SetOutValue
Fc9-comp-macro.png SetOutValue
Range 0-4
Fc9-string-icon.png - STRING value
