Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images ## Miscellaneous ## Symbols ## Circuits ## Logic Gate Reference * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Miscellaneous<^< Other Images | Course Index | Symbols >^>(:nl:) >>frame round<< This female 5-way DIN connector is used for audio and general purpose signal applications. >>frame round<< This male 5-way DIN connector is used for audio and general purpose signal applications. >>frame round<< The miniature coaxial SMA connectors are used for very high frequency (VHF) and ultra high frequency (UHF) applications. This type of connector is designed to be used in a matched 50W system. >>frame round<< Single-pole connectors like this 4mm terminal post are used for power and test instrument connections. >>frame round<< Phono connectors are used for low-cost audio applications. Such connectors are normally used with coaxial cables which use an outer copper braided screen to reduce the effects of hum and noise. >>frame round<< Solid-state relays are used to control mains-connected loads such as lamps and motors from a low-voltage low-current source. Relays of this type provide a very high degree of electrical isolation between the controller and the controlled circuit. >>frame round<< Relays provide a means of switching relatively large currents and voltages from very much smaller currents and voltages. In addition, relays can provide a very high degree of electrical isolation between the controller and the controlled circuit. This miniature dual-in-line (DIL) relay is designed for printed circuit board mounting. >>frame round<< This plug-in relay operates four separate sets of changeover (CO) contacts, each rated at 250V 1A. The relay coil requires an operating current of 75mA at 12V. >>frame round<< Quartz crystals provide the frequency determining element in many precision oscillator and clock circuits. Each crystal comprises a thin slice of quartz - the physical dimensions and "cut" determining the exact frequency of resonance. These three crystals are designed to produce frequencies of 100kHz, 1.8432MHz and 3.2768MHz. Many other standard frequencies are available. >>frame round<< Voltage dependent resistors (or varistors) are designed to protect circuits and equipment from transient pulses (or 'spikes') which may be present on voltage supplies. Varistors have resistances that fall to a very low level whenever a particular threshold voltage (of either polarity) is exceeded.
Page last modified on July 26, 2011, at 09:50 AM
