Recent Changes - Search:
<^< Potential and Current Dividers | Course index | Worksheet: Potential Dividers >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers ##
Potential Dividers ## Worksheet: Potential Dividers ## Current Divider ## Worksheet: Current Divider * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Potential Dividers
<^< Potential and Current Dividers | Course Index | Worksheet: Potential Dividers >^>(:nl:)
The potential divider circuit is used to reduce voltage levels in a circuit. The output voltage produced by the potential divider is a fixed ratio of its input and it is given by:
V'_out_' = V'_in_' x R'_2_' /(R'_1_' + R'_2_')
It is, however, important to note that the output voltage (V'_out_') will fall when load current is drawn from the circuit arrangement. The reason for this is that the resistance of any load connected to the output of the potential divider will appear in parallel with R2 and this will effectively reduce the value of the lower resistor of the potential divider and consequently it will also reduce the voltage drop produced across it. (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 10:06 AM
