Recent Changes - Search:
<^< Phase | Course index | Examples: Voltage and Turns Ratio >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers ## Transformer Operations ## Examples: Transformer Operations ## Phase ##
Voltage and Turns Ratio ## Examples: Voltage and Turns Ratio ## Current and Turns Ratio ## Examples: Current and Turns Ratio * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Phase | Course Index | Examples: Voltage and Turns Ratio >^>(:nl:)
The voltage produced across a transformer winding is directly proportional to the number of turns on the winding. Thus:
V'_P_'/V'_S_' = N'_P_'/N'_S_'
where V'_P_' is the primary voltage, V'_S_' is the secondary voltage, N'_P_' is the number of turns on the primary winding and N'_S_' is the number of turns on the secondary winding.
The ratio of primary to secondary turns on a transformer, N'_P_'/N'_S_' , is known as the turns-ratio of the transformer.
Finally, the turns-per-volt rating for a transformer is sometimes quoted. This rating is given by:
t.p.v. = N'_P_'/V'_P_' = N'_S_'/V'_S_'
>>id=box1 class=toggle center<<
Diagram of transformer turns ratio
>><< >>id=box2 class=toggle center<<
>><< >>id=box3 class=toggle center<<
ratio = 1:2
ratio = 1:1
ratio = 2:1
(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 03:12 PM
