Please advise why the attached does not compile, message file also attached
fail to compile
- Has thanked: 27 times
- Been thanked: 8 times
fail to compile
- batt_sim_1.fcfx
- (16.38 KiB) Downloaded 39 times
- batt_sim_1.msg.txt
- (1.76 KiB) Downloaded 41 times
Re: fail to compile
I have redone the fcfx in v9 which does compile fine
- bsim1.fcfx
- (12.96 KiB) Downloaded 40 times
- Has thanked: 454 times
- Been thanked: 612 times
Re: fail to compile
It's down to your font selection. The v10 project contains two fonts, a 24 pixel one and a 32 pixel numeric one which are both require fairly large amounts of ROM. The v9 project you created only has a single font which is the default 8 pixels high font which is much more concervative.
As your device is fairly limited in ROM memory then you can use a low pixel font and the gLCD SetFontScaler component macro to scale up the font on the display if you need bigger text sizes.
Hope this helps to explain things.
