Arduino Questions
steve001
Has thanked: 81 times
Been thanked: 30 times
Arduino Questions
Post by steve001 »
Afternoon All,
Been given a few bits, and wondering if they compatible with flow code, not having experience with Arduino stuff
Looking at the website, looks like a copy and has 30 pins the flow code drop down menu's show 32 pins ?
Also there is somthing mentioned about the USB chip swapped for a cheaper CH340 USB IC - would this affect programming or would i be better of using ICSP header ?
any other gotcha's ?
Have seen a post following a search - not sure if he / she got the display working
Anybody used one of these ?
Starting to wonder why i got them given :roll:
Has thanked: 439 times
Been thanked: 603 times
Re: Arduino Questions
Hi Steve,
Provided it has a genuine AVR on it I think it should work fine. The bootloader is usually the same as it's open source and so programming should work as is with a genuine Arduino. You may need to install USB drivers for the USB to Serial chip but these should be easily available from Google. Personally I've had a lot of success with the very low cost Chinese type Arduino clones.
The only thing different you need to do when using Arduinos from say PICs is to set the COM port to the device within the project options.
Has thanked: 509 times
Been thanked: 472 times
Hi Steve,
steve001 wrote:
Wed Nov 17, 2021 1:48 pm
I use one of them a lot of the time and I know of other forum members that use one as well.
They work really well.
Just remember that it could use one of two addresses.
Either 0x3F (63) - Like mine
or 0X27 (39)
You can test with a sniffer
You won't need pull-ups as they are included on the PCB.
steve001
Post by steve001 »
thank guy's
Got the driver shows up as in device manager
Com Port.JPG (12.21 KiB) Viewed 2700 times
not sure what target to pic ?
is it the Duemilanove 328P ?
and
can you explain a bit not sure what you mean
@ Martin,
Thank you will have a go with normal 4 bit display first then have a go with this one later
steve001 wrote:
Wed Nov 17, 2021 3:43 pm
That just means with Arduino, you need to select the correct COM port from within Project Options.
It should not be n/a:
Select Com Port.png (67.76 KiB) Viewed 2689 times
I would just try the nanao 328. So long as the chip and clock speed match the project options
steve001
Post by steve001 »
Bit Confused if somebody can point me in the right direction please
looking on the tinterweb gives this information
selecting Nano 322 as my target device
When mapping port pins flowcode shows the actual device not the nano
Screenshot 2021-11-19 152049.png (148.93 KiB) Viewed 2648 times
how do i know which pin is which ? - or am i missing something ?
unticking "use chip references " shows a number is this the Nano pin number ? - but this raises another question what is pin 0 ?
Hi Steve,
When chip references is unticked pin0 = pin D0 or Pin 2 of the Nano. This matches the way the digital pins are numbered in the Arduino IDE.
steve001
Post by steve001 »
Cheers Ben
