Hello together,
just a add on in relation to the BT connectivity.
I testet some samart phone Android BT terminal APP´s.
"Bluetooth Terminal HC-05" Pro or non Pro Version works and is stable with my ESP-32.
BR
Dirk
Bluetooth spp does't work in ESP32
dvcam99
- Has thanked: 9 times
- Been thanked: 14 times
- Has thanked: 177 times
- Been thanked: 1026 times
Re: Bluetooth spp does't work in ESP32
I'm trying to get Bluetooth working on a Heltec wifi kit 32.
I altered the sdkconfig as per previous posts but I get linker errors:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP/ESP_CAL_BT_SPP.c:210: undefined reference to `esp_bt_gap_pin_reply'
h:/.espressif/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP/ESP_CAL_BT_SPP.c:214: undefined reference to `esp_bt_gap_pin_reply'
h:/.espressif/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(esp-project.c.obj): in function `esp_spp_cb':
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP/ESP_CAL_BT_SPP.c:138: undefined reference to `esp_bt_gap_set_scan_mode'
Trimmed for readability - but there are several of the 'undefined reference' errors on linking..
Anyone got this working?
As an aside - the forum search function ignores a lot of words (for example I can't search for esp32 bluetooth) - I'd prefer to get lot's of results than none?
- Has thanked: 794 times
- Been thanked: 853 times
I fully agree with Martin.
Search on the Martrix forums for bluetooth and you get
Search found 642 matches: bluetoothCode: Select all
The following words in your search query were ignored because they are too common words: bluetooth.Martin
- Has thanked: 310 times
- Been thanked: 479 times
Regarding the search issue, I've changed the threshold level for common words from 5% to 30% so you shouldn't have this problem in the future.
- Has thanked: 246 times
- Been thanked: 258 times
I have tried all the tips listed here but no success.
There are no errors when compiling, but neither my computer nor my phone can find the bluetooth signal.
I tried two different modules without success
It's working again with the M5 Atom board.
But I don't know why.
I guess, because every time I rename the program or copy it to another folder I have to redefine the two lines in the sdkconfig file.
On this occasion I would like to mention the simple drag and drop of Flowcode for ESP32 Bluetooth. You don't need a pin or baud rate and you never confuse about rx and tx pin. And simple to choose a Bt name. Also to check if it's connected is so easy.
# Bluetooth
CONFIG_BT_ENABLED=y
# Bluetooth controller
# CONFIG_BTDM_CTRL_MODE_BLE_ONLY is not set
CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
- FC9_M5STACK_Modul_Atom_BT.fcfx
- (9.25 KiB) Downloaded 1072 times
- (view online)
- BT-ok.png (97.92 KiB) Viewed 16768 times
- Has thanked: 647 times
- Been thanked: 856 times
Hi Stefan,
Glad you've got it working now. I would like to revisit Bluetooth on the ESP32 soon and get some of the more modern Bluetooth profiles working. Would you have any need for anything specific to be supported?
A small wish, is to read the uniq ID from the Bluetooth part.
Yes the A2DP is an option
This enables me to stream my measurement data directly into Audacity. I had done this many years ago with a Microchip module.
Of course you can also send sound, to some bluetooth speaker.
A2DP (Advanced Audio Distribution Profile) is a Bluetooth protocol that enables a headset to stream high quality stereo audio wirelessly from a smartphone or other compatible device. The quality of the audio is much better, both for calls and for music playback.
I have two wish more...
1. A command to set the RF Power from the Bluetooth (to reduce it).
2. I have a recorder with 2 external Sensor, all the 3 are programmed with Flowcode and ESP32.
When I turn on all the 3, the recorder should connect automatically with the 2 sensors. It's always a set and the distance between the recorder and sensor is just about 0.5meter. In the recorder is permanently programmed the same two sensors it has to be connected
This funktion can also be used if just 2 ESP32 boards need to be connected by Bluetooth, without a computer or a user input.
What about a files transfer protocol?
OBEX-FTP File Transfer Profile
Bluetooth file transfer is a simple way to send files to another nearby Bluetooth device without the need for a separate app. Bluetooth is compatible with smartphones, tablets, laptops, and desktop computers. Files can be transferred over Bluetooth using Android OS, Fire OS, Blackberry OS, Windows OS, Mac OS, and Linux OS.
