Hello, I've found a problem with 2 components when they are combined together.
Those components are the Ultrasonic Ranger (Grove 101020010) and the Timer (in the storage component library)
Individually these components work as expected however both placed in the environment with the Arduino Uno board seems to produce an error when compiling to Hex therefore unable to compile to the board.
Is there any workaround to this issue as I need both for my project, thanks in advance!
Grove Ultrasonic Ranger and Timer Issue
Re: Grove Ultrasonic Ranger and Timer Issue
Yep, here's a project with the two components mentioned, if you try to compile to hex (or to target) you will see the issue on the log :)
Yes, I have the same problem and I spent over 2 hours on it before reading this. The thread seems to have gone quiet - is there a workaround or can a different timer be used with Arduino Uno R3 PDIP? I want to use 'ping' and time the measurement. We spent good money on EBlocks2 & Flowcode!
- Has thanked: 439 times
- Been thanked: 603 times
This problem is caused by two things.
1) the timer component is clashing with the free timer component nested inside the ultrasonic component.
2) the timer and the ultrasonic component timer are both pointed at the same timer resource (timer1).
I might try and solve problem 2 for you but this is a very corner case issue so I might leave it as it is for now.
I have now edited the free timer component to remove this clash and pushed the change to the update system.warning: "TIM_1_INC" redefined
The ultrasonic component is set to time measurement using delays but the definitions for the underlying hardware timer are still active. I haven't yet been able to solve this one for you so you can either change the timer connected to the timer component or you can temporarily change the time measurement of the ranger component to allow you to assign a different timer peripheral.error: redefinition of '__vector_9'
