Hello I use Atmega128 processor and AT25F4096 memory.
Writing to memory works correctly but reading always returns 1.
Flash W25 reading doesn't work
- Has thanked: 1 time
- Been thanked: 3 times
- W25.fcfx
- 3
- (16.37 KiB) Downloaded 91 times
- 2
- W25.jpg (45.27 KiB) Viewed 3331 times
- 1
- Prog.jpg (28.79 KiB) Viewed 3331 times
- Has thanked: 449 times
- Been thanked: 609 times
Re: Flash W25 reading doesn't work
You might need to erase the block first before you try and program the location. Though 255 would potentially indicate an unprogrammed location.
Erasing does nothing!
Cleaning up didn't do anything either.
Made a write / read loop and the loop stops.
the program hangs. Recording doesn't work.
Only reading works.
Only reading works.
- MEM.fcfx
- (24.05 KiB) Downloaded 85 times
- 1
- Ind.jpg (91.51 KiB) Viewed 3257 times
What do you have the WP pin connected to?
When connected according to the datasheet, there is not even a read.
And if the pins MOSI and MISO swap places, the chip returns 255. This is the default value.
In the program you can see that I set the value to 0 and the return value to 255. So the reading is done. But the sector is not unlocked and therefore not written.
Respectfully Osta
Respectfully Osta
