ATTINY44 the interrupt doesn't work TMR1
- Has thanked: 1 time
- Been thanked: 3 times
TMR1 interrupt does not work in the hardware
- BG.fcfx
- bg
- (15.47 KiB) Downloaded 73 times
- Has thanked: 440 times
- Been thanked: 603 times
Re: ATTINY44 the interrupt doesn't work TMR1
I've had a look through the datasheet and compared with the generated code and I think I might have found something. The interrupt vector was declared as TIMER1_OVF but it looks like this might not be correct on this device, annoying it doesn't generate a compilation error to make it more obvious. I've changed it to TIM1_OVF and hopefully that will solve the problem for you.
The latest fixes are now available via the update system. Let us know how you get on.
downloaded the update but it's not working. Now it doesn't work in the emulator either.
- ModUpr.fcfx
- (15.06 KiB) Downloaded 66 times
Checked in the iron all works, but in the emulator stopped working.
Regards Osta.
Regards Osta.
- ModUpr.fcfx
- (15.09 KiB) Downloaded 73 times
Great glad the hardware is working as expected. What emulator are you using?
Hi!
Sorry I didn't reply right away, I was on vacation.
I use PROTEUS.
Respectfully Osta.
