SPI version of the ST 7920 GLCD
estevaon
Been thanked: 1 time
Flowcode v10 SPI version of the ST 7920 GLCD
Post by estevaon »
I'm using a ST 7920 GLCD in a project, but it doesn't works in parallel mode ( and use too many pins), I'ts possible to create a SPI version to this component?
Has thanked: 449 times
Been thanked: 609 times
Re: SPI version of the ST 7920 GLCD
Yes looks possible, on your display do you have access to the pin (PSB) that sets if the display has a parallel or serial interface? This is often the limiting factor.
estevaon
Post by estevaon »
Hello BenR,
Yes, this pin (PSB) exists.
Great, I've made the change to the component to allow it to be configured as an SPI mode. I've not tested it so let us know how you get on.
The latest version is now available via the Help -> Library updates.
estevaon
Post by estevaon »
Thank's Ben, it will very useful. I'll test and report the results.
estevaon
Post by estevaon »
Hi BenR,
Unfortunately, the SPI mode doesn't work, squares appear instead of letters.
Ok sounds like the write is maybe working but the read back isn't. I'll have another look at the code.
estevaon
Post by estevaon »
Thank's BenR
