programs that compile to hex and picket3 compile sussessfully in ver 8 but wont compile in ver 10.
I get the following message.
Copyright (C) 2019 Microchip Technology Inc.
Ver7cardK22.c: FCD_0f5c1_TCPIP_ENC28J60__MakeArpRequest()
4412: FCV_0f5c1_TCPIP_ENC28J60__BUFFER[0x26 + FCL_IDX] = FCL_SERVERIP[FCL_IDX];
(192) undefined identifier "FCL_SERVERIP" ^
(981) pointer required ^
(908) exit status = 1
upgrade to Version 10
Roy_Johnston
Roy_Johnston
Re: upgrade to Version 10
i attach my flowcode file
- Ver7cardK22.zip
- (16.18 KiB) Downloaded 342 times
- Has thanked: 154 times
- Been thanked: 887 times
It looks like an issue in TCPIP_ENC28J60__MakeArpRequest
The arguments are declared as "MX_UINT8 **PFCL_SERVERIP"
but then used as "FCL_SERVERIP[FCL_IDX];"
Does the component need recompiling for v10? or has the way arrays get passed/named changed slightly?
Roy_Johnston
I have no Idea,
I assume it’s the component.
the same file works in ver 8 but does not compile in ver 10.
I can compile and program the chip with basic software. As soon as I introduce the initialize 28J60 component it gives this error.
I recompiled the component - using v10 - having changed the name of the parameter (ServerIP) to XServerIP (so I could check that the change had taken effect)
This then allows the code to compile okay...
If you pop this into your FC component directory (C:\ProgramData\MatrixTSL\FlowcodeV10\Components) then reload your project - and try again...
Roy_Johnston
Ok its compiling now all is ok except for one issue. the leds on the enc18j60 don’t flash when initialising. This is a nice feature to have as it indicates to my customers all is ok.
thank you.
thank you.
Roy_Johnston
Roy_Johnston
yes it did.
if i take the same file and load it onto ver 8 it flashes to indicate the leds ( ledA and LedB on the enc28j60)
no i dont have any code.
