============================== Toolchain Check ==============================
ERROR: Python is not installed
git version 2.21.0.windows.1
ESP toolchain found at "C:\Users\Kfs-Forschung\Desktop\esp-idf\"
Building: C3_24_1 ...
IDF Version: v5.1.2 ...
Error: The following tools are not installed in your environment.
but if I type python it should show me Python 3.12
C:\Users\Kfs-Forschung\.espressif\frameworks\esp-idf-v5.1.2>python
Python 3.11.2 (tags/v3.11.2:878ead1, Feb 7 2023, 16:38:35) [MSC v.1934 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
Hi Stefan.
If it was me seeing that message, I would uninstall ESP-IDF and python.
Make sure both esp-idf & esp-idf-tools directories are deleted and start from fresh following the guide here.
It has not let me down to date.
Yes I installed Python 3.7 again and selected it by the setup. And now it's working again.
Sooner or later we will have to change Python version and i suspect the problem is just in the toolchain check
The effort is small and makes it possible to programme the ESP32 C3 and ESP32 S3 with Flowcode. Who knows, maybe BLE.... will follow
Yes idf v5.1.2 and Python 3.11 worked for the new ESP32 S3 and ESP32 C3.
But I had problems with the "old" ESP32. I could no longer configure Bluetooth. So I had to use Python 3.7 again.
I am still having problems with the changeover to ESP -IDF 5.12.
The problems are not the new ESP32 C3 or S3 versions but the "old" ESP32
One of the problems, I cannot open the menu to setup Bluetooth.
It is also not clear to me whether I should work now with Python 3.12 or 3.7.
Hi Stefan.
Try deleting the current build files which are located in a folder next to your Flowcode project file with the same name.
Or you could just rename the folder.
