Has any one managed to implement a hilbert filter in flowcode
I have been experimenting using coefficients from IWOA hills program into the FIR component
I am looking to achieve 2 filters one +45 deg and one minus 45deg
each with cut off around 2.8khz ideally with 70+ taps
Have tried sampling at 10khz and 20khz but FIR filter loop appears to slow down all the other loops
Note i have tried reducing the number of taps but still similar
Note i did try the in built "low pass filter" component and that appears to operate okay but obviously does not give me control of the phase angle i require
Any ideas or exeperiances
David
DSP Hilbert filter
DAVIDJOINER
- Been thanked: 18 times
