UART "SendString" command problem [SOLVED]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Re: UART "SendString" command problem
Post by Sasi »
Thank you very much for trying it out.
Would you be so kind to attach the .fcfx, .c, and .h files from the program compilation results to the post.
I would like to compare them with what I get as a compilation result.
Sasi
Has thanked: 724 times
Been thanked: 783 times
Sure - files attached as requested.
UART_Test_2_NOT Working.h
(9.02 KiB) Downloaded 172 times
UART_Test_2_NOT Working.c
(55.64 KiB) Downloaded 185 times
UART_Test_2_NOT Working.fcfx
(17.49 KiB) Downloaded 192 times
Sasi
Post by Sasi »
Sorry, I would like to request the .hex extension instead of .h. :oops:
celebriums
Has thanked: 25 times
Been thanked: 13 times
Post by celebriums »
Dear Sasi
Can you remove the processor and try with a new processor? Maybe your processor is failing due to static electricity or something like that.
I can understand that you are overwhelmed by this problem, it's very frustrating.
I am asking to be sure of the oscillator speed of your processor, is the 1 second led blink test positive? Please test it on an oscillascope or logic analyzer.
I am waiting for your answer.
Sadık
Sadık Süme
Sasi wrote:
Thu Apr 17, 2025 10:37 am
Not a problem.
Zipped up as .hex file can't be sent
UART_Test_2_NOT Working hex.zip
(806 Bytes) Downloaded 172 times
Sasi
Post by Sasi »
The .hex file you sent works. :D
There is no difference in the code between the .c files.
Would reinstalling Flowcode fix the problem?
What would you suggest?
Sasi
First without modifying the .fcfx file I sent, compile and load your Microcontroller.
If it works you have a configuration issue with your ,fcfx file.
Follow what Sadık has suggested and run a a 1 sec flash test and measure the time duration the LED is on for, or you can use a scope or a logic analyser.
If it does not work, then make sure you update your component library with the Full database option.
Reload your .fcfx project and try again.
celebriums
Sasi
The problem is not in the C file,
As far as I understand, there is an error in your configuration settings. Cyrstal Settings
Can you write down the values of those settings?
// Enter C code below this comment
OSCCON = 0x70; //16MHz
st_bit(OSCTUNE,PLLEN);
uses the internal oscillator with this command. Remember :D
Sadık
Sadık Süme
Sasi
Post by Sasi »
Hi Martin and Sadık,
I did a clean install of Flowcode10 on a desktop. I installed all the library updates. I compiled the .fcfx file Martin sent me, but the UART output didn't work.
Then I thought I'd try different versions of the XC8 compilers.
XC8 v2.10 (the default compiler for Flowcode 10) and XC8 v2.46 produced a non-working .hex file for me. XC8 v3.00 gave me errors during compilation, so I didn't experiment with it any further.
XC8 v2.50 is the winning compiler. It seems to only work with v2.50, although I haven't tried all the possible versions.
It helped a lot to solve the problem that I received working project files from Martin.
Thanks again.
Sasi
If I compile with XC8 v2.50, will other errors occur during program compilation?
Thanks Sasi,
That is interesting.
I use XC 2.50 since I'm adding new target devices.
I know XC8 v3.0 is not compatible with Flowcode.
Sasi wrote:
Fri Apr 18, 2025 5:26 pm
What errors did you get with v2.50
