Mikroe AlphaNum R Click (TI TLC5926) component
andeug
Has thanked: 37 times
Been thanked: 6 times
Flowcode v11 Mikroe AlphaNum R Click (TI TLC5926) component
Post by andeug »
I am thinking of buying the board Mikroe AlphaNum R Click to start experimenting with a different shift register than the 74HC595/TPIC6B595, so I found the TLC5926, a 16-bit constant-current LED-sink driver from Texas Instruments. Is anyone interested in making a component for it?
https://www.mikroe.com/alphanum-r-click
I found that 14-16-segment displays aren't very popular in Flowcode's library...
Andreas
Has thanked: 163 times
Been thanked: 960 times
Re: Mikroe AlphaNum R Click (TI TLC5926) component
Post by mnfisher »
andeug
Post by andeug »
Thank you for the link, Martin!
By the way, what do you think of MAX6954?
It looks quite capable, and also supports many other features. it's definitely the solution for space and component-saving, but it comes at around 35EUR/unit, according to Mouser.
https://www.analog.com/en/resources/des ... x6954.html
https://www.analog.com/media/en/technic ... ax6954.pdf
Post by mnfisher »
The MAX device looks very good - and is ideal for using with small MCUs as it has the built in character set.
The HTK chip I used doesn't have this - so there is a cost in memory usage but a lot cheaper for the part itself. I did look at the MAX development board, but decided it was just too expensive (~£100) as I didn't have an immediate use for it.
Programming wise - they (and the driver in the Mikroe board) - are very similar. Indeed I'd been playing with the MAX7219 at the time - and the code has many similarities to that too.
There wasn't much interest in the HTK board so I kinda left it to the side and moved onto something else - but these displays make a neat display option and can display a much wider range of info than the 7 segment devices. The cost may be an issue - a OLED / LCD can display even more - and come in at a similar price?
andeug
Post by andeug »
Where have you seen the development board/kit with MAX6954? I have only seen this:
https://www.remelectronics.com/2023/09/ ... ay-driver/
It's not that expensive, and I could buy it for you if you want to make a component from it.
LE: I found it, the development kit is with MAX6955 and I think it worth the money, especially for how much time it saves and the components it has:
https://www.mouser.se/en/ProductDetail/ ... ujQA%3D%3D
Andreas
Post by mnfisher »
Ah - I did indeed see the 6955 :-)
Yes - if you'd like to lend (or send) me a board - I'd happily get some code going on it...
andeug
Post by andeug »
Martin, are you based in the UK?
I could eventually order one from Mouser and send it to your home address.
After you are done with it, you can either keep it or send it to me (and I will pay for shipping).
I think it would be useful for the whole community if someone like you could create a component for that display driver...
Post by mnfisher »
Yes, I'm in the UK. I can PM you my address...
Has thanked: 442 times
Been thanked: 661 times
Post by chipfryer27 »
I looked at the link and think it an expensive purchase (around £90+) especially as the associated datasheet informs it has a DB25 connector for connection to a computer's printer port and is compatible with OS's that disappeared decades ago :lol:
Clearly documentation hasn't been updated.
Other links show it can be obtained for around US$20 with SPI interface.
