ESP32 CAL SPI error
Has thanked: 160 times
Been thanked: 950 times
ESP32 CAL SPI error
Post by mnfisher »
Whilst trying to get SPI working on a Heltec Wifi kit..
I notice PRESCALE_VAR_X in CAL\ESP\ESP_CAL_SPI.c is defined as a MX_UINT8. (Line 106)
This is likely to not work well (it is calculated from Prescale (PR_SCALE) which is 1..800 so the result won't fit into 8 bits.
Pin assignments for hardware channels still don't seem to work correctly.
Re: ESP32 SPI Type error
Post by mnfisher »
Another problem with cal_spi.
I actually noticed this when I converted an Arduino project to ESP32 (modded the project SPI to transaction mode) - found my esp32 board seemed to have died and then converted back to Arduino (changing the project type here is VERY slooowwww)
This is easily replicated by starting with an esp32 project:
Create a project for ESP32 (I used Heltec Wifi Kit 32) and add a cal_spi component. Optionally - add a call to Master_Init()
Then convert project type to Arduino (I used Nano)
Then the cal_spi component now has a prescale of up to 80MHz (and project won't compile if any calls (ie Master_Init) to SPI added)
LeighM
Has thanked: 103 times
Been thanked: 301 times
Re: ESP32 CAL SPI error
Post by LeighM »
Hi Martin
Thanks for the spot, but we don't actually use the PRESCALE_VAR_X variable, we use MX_SPI_PR_SCALE_X directly instead on ESP.
Do any pin assignments work for you, or is it any pins in particular?
Post by mnfisher »
Thanks Leigh,
- The pins are not 'auto-selected' on choosing channel 1 or 2 and just stay 'locked' on whatever they are set to. Have to change the remap pins here...
The Prescale - threw up a compiler warning so was an easy spot whilst traying to work out why my code wouldn't compile after changing from Arduino....
Any thoughts on the 'downgrading' to Arduino problem - I manged to patch the XML on a small project (using the Compare add-on in Notepad++) but it's a delicate task on a bigger one, and FC crashes on little mistakes.
LeighM
Post by LeighM »
- The pins are not 'auto-selected' on choosing channel 1 or 2 and just stay 'locked' on whatever they are set to. Have to change the remap pins here…
I think that’s intentional as the preferred action in most cases, i.e. the remap pins stay as the user selection when the channel is changed.
The Prescale - threw up a compiler warning so was an easy spot whilst traying to work out why my code wouldn't compile after changing from Arduino.…
Good point, I will edit the code to remove the warnings.
Oh, I see what you mean now, that’s an interesting bug. Will investigate further.
LeighM
Post by LeighM »
Saving and re-loading the project corrects the component properties (spotted by Ben)
Post by mnfisher »
Thanks - that's an easy fix....
Post by mnfisher »
Unfortunately - saving re-loading doesn't seem to work on larger programs....
