I am experiencing a problem with the XPT2046 touch controller when using hardware SPI in Flowcode 11.
Hardware
- LCDWiki E32R40T
- ESP32-32E
- Display controller: ST7796S
- Touch controller: XPT2046
- Display resolution: 320 x 480
The display and touch controller share the same SPI bus, as intended by the board manufacturer:
- MOSI: GPIO13
- MISO: GPIO12
- CLK: GPIO14
- Display CS: GPIO15
- Touch CS: GPIO33
- Touch IRQ: GPIO36
Flowcode configuration
Both components are configured to use:
- Hardware SPI Channel 1
- Identical SPI prescaler, tested at 2 MHz and lower
- Separate CS pins
- XPT2046 analogue mode: Differential
- Display and touch orientation: 1
Problem
When both components use hardware SPI:
- The ST7796S display works correctly.
- The XPT2046 touch controller produces incorrect results.
- SampleSensor() sometimes returns 254 even when the screen is not being touched.
- The returned X/Y coordinates are completely incorrect.
When I change the XPT2046 component to software SPI:
- Touch detection works correctly.
- The X/Y coordinates are correct.
- However, the ST7796S hardware-SPI display then stops working because both devices share GPIO12, GPIO13 and GPIO14, and the software-SPI component appears to reconfigure these pins.
I also tested:
- Different initialization orders
- Both components using software SPI
- Lower SPI clock frequencies
- Single Ended and Differential analogue modes
These tests did not provide a usable configuration for both devices.
Similar existing report
I found a very similar report involving an ESP32 CYD and XPT2046:
viewtopic.php?t=3564
In that case, hardware SPI also produced incorrect coordinates, while software SPI solved the touch problem.
Software SPI is not a viable workaround for the E32R40T because the ST7796S display and XPT2046 are permanently connected to the same physical SPI pins.
The board works with the manufacturer's software, so the hardware and wiring appear to be correct.
Could Matrix please investigate whether the XPT2046 component has a problem using ESP32 hardware SPI, especially when sharing the SPI channel with a graphical display component?
I can attach my complete Flowcode test project for reproduction.
Thank you.
XPT2046 wrong coordinates using shared hardware SPI on ESP32
Kimba
- Has thanked: 634 times
- Been thanked: 842 times
Re: XPT2046 wrong coordinates using shared hardware SPI on ESP32
Please can you attach your project file for me to investigate further.
The main thing I am assuming is the SPI mode for the display and the touch sensor are different and that's what is causing the problem.
In the Flowcode simulation, the touch areas assigned to the Display Manager objects work correctly. I have not verified the exact numerical X/Y values in simulation.
The problem occurs on the physical ESP32 hardware.
Please let me know if you need any further tests on the E32R40T hardware.
A.C
A.C
- E32R40T_E32N40T_Specification_V1.0.pdf
- (1.96 MiB) Downloaded 7 times
- ESP32_4inch_ST7796_XPT2046_Display_Test.fcfx
- (31.12 KiB) Downloaded 9 times
- (view online)
Good news — the ST7796 display and XPT2046 touch are now working together over hardware SPI! Thank you for your suggestion about the SPI clock phase.
Here is a chronological summary of the investigation and successful test:
Initially, the display worked correctly with hardware SPI, but the touch returned incorrect coordinates and detected touches without any physical contact. The touch responded correctly when using software SPI.
Checking the generated code showed that both components use hardware SPI channel 1, with the same bus pins and a 2 MHz clock setting. The generated header sets both MX_SPI_BMODE_1 and MX_SPI_BMODE_2 to 0.
Further inspection of ESP_CAL_SPI.c revealed that BMODE = 0 maps to ESP32 SPI mode 1, while BMODE = 2 maps to mode 0.
The first attempt was to set BMODE = 2 through a modified copy of the project. However, Flowcode did not retain this change: the regenerated header still contained BMODE = 0 for both instances.
The next step was a local CAL test modification: explicitly setting MX_SPI_Mode_1 = 0; during hardware SPI channel 1 initialisation, overriding the calculated mode. The clock speed, pins and touch calculations were unchanged.
After replacing the CAL file, recompiling and flashing the original test project, the display and touch worked together correctly over hardware SPI.
This result supports your suggestion about the clock phase. The modification is currently only a diagnostic workaround, since it forces mode 0 for hardware SPI channel 1 and can affect other projects using that channel.
Could you please review the findings and the attached modification, confirm whether the permanent correction belongs in the components’ SPI settings or in the ESP32 CAL, and validate the final fix before releasing an official update through Flowcode’s Library Updates? The current modification has only been tested on my hardware setup.
The project used for the successful test is the one I already uploaded. I have attached the original and modified ESP_CAL_SPI.c files for comparison.
Thanks again for your quick support — really pleased to have the 4-inch display and touch working!
Best regards,
Best regards,
- SPI_Mode0_CAL_Test_.rar
- (9.54 KiB) Downloaded 10 times
