Not so much a bug as a 'gotcha'.
On most MCUs (at least AVR and PIC) - using a Rx interrupt on a UART the interrupt is UARTRXn where n is the channel number - 1.
On the esp32 - n is the channel number. This is, of course, much more sensible - but change for other devices might break many things?
The esp32 UART is rather different to other MCUs (there is a hardware buffer for example) - and behaves more like a PC UART. However, I was aiming for portable code that would work on a range of devices. The component doesn't really allow for this functionality to be used.
It's easy enough to work around (with an #ifdef ...).if nothing else.
ESP32 UART interrupts
- Has thanked: 177 times
- Been thanked: 1026 times
