arduino uno R3
jeancharlesgras
arduino uno R3
Post by jeancharlesgras »
problem compiling on arduino uno
when I transfer this file Flowcode1.fcfx to the arduino uno support, it works correctly the leds flash at the right frequency
but when I want to control the leds by a potentiometer essai arduinouno r3 pot.fcfx it does not work
Is it a driver or configuration problem?
Thank you for your reply
jcg
Flowcode1.fcfx
(8.01 KiB) Downloaded 248 times
essai arduino uno r3 pot.fcfx
(10.07 KiB) Downloaded 285 times
Has thanked: 292 times
Been thanked: 458 times
Re: arduino uno R3
Maybe an issue with the wiring on the Arduino?
In your first program, the LED is connected to pin12 and in the second it is connected to pin 13. Is that the problem? Also check that the pot is correctly connected to A2 as per your program.
jeancharlesgras
Re: arduino uno R3
yes, I noticed it, I fixed it but the problem remains the same. I still can't get my arduino to work with a potentiometer (ADC) as input
in simulation (debugging) this is ok, but not on the board
(9.92 KiB) Downloaded 271 times
Has thanked: 724 times
Been thanked: 783 times
Re: arduino uno R3
Hi.
Now that you have fixed the issues Steve suggested.
The default Vref Option settings for ADC is AREF.
If you look at your ADC properties & change Vref Option from AREF to AVCC, you should be good to go.
jeancharlesgras
Re: arduino uno R3
I changed the AVref configuration to AVCC, but I still have the same problem, I think more of a driver or compilation parameter problem. I use AVRISPmkII , when I transfer to an ECIO28 it works correctly on the model
Re: arduino uno R3
Flowcode will program the Uno directly via USB.
There is no need to use AVRISP.
Just as a saintly check, I have tried the flowchart you posted on my Uno & it works as expected (after changing Vref options).
Is the Uno bootloader still intact, or has it been overwritten?
jeancharlesgras
Re: arduino uno R3
I just loaded the bootloader, I think it was faulty and this time it works fine
thank you very much
and happy new year 2022
Re: arduino uno R3
That's great.
Thanks for letting us know and happy new year to you too.
