ECIO 40p
Has thanked: 374 times
Been thanked: 585 times
ECIO 40p
Slightly off topic FYI
At the same time I bought the ECIO28p I also bought an ECIO40p16 (dsPIC). Never looked at either until now and I find the dsPIC is actually a ECIO40p... Oh well, I should have checked at the time... :)
Loading the drivers on the W7 laptop I again get the connect / disconnect sound straight after each other and nothing shows up in Device Manager, just like the ECIO28p. However the led on the 40p is almost imperceptible. From within FC if I try to compile to chip it gets as far as telling me that I need to press the reset button, but nothing happens if I do.
If I use mLoader to send the hex then I have no issue.
I'll probably get around to trying on W8.1 later in the week.
Has thanked: 646 times
Been thanked: 704 times
Re: Connecting to ECIO 28p
Hi.
There was a batch of ECIO40's that got the outer GND track chopped off at the PCB manufacture stage.
All you need is a link from one GND pin to the other GND pin.
Thanks for the info. I'll fix that later in the week.
Getting the ECIO28p was mainly to explore FD but as the ECIO range is now discontinued I probably won't spend too much time with them other than "play".
Re: ECIO 40p
No problem.
I have spit the topic as the other one was getting a bit hijacked.
It's a shame it has been disconnected as it's a good bit of kit.
Re: ECIO 40p
Hi Martin
Connected both GND pins to each other and now it all works fine. When prompted by FC to press reset it now proceeds to download.
Still doesn't show up in Device Manager though (W7) but that's not a problem to me.
Re: ECIO 40p
Hmm, it's not for me now.
Maybe I had something else plugged in and not realised it.
Sorry about that.
