Looking for examples: LilyGO TTGO T-Display ESP32
MJU20
Has thanked: 105 times
Been thanked: 74 times
Post by MJU20 »
I've bought a "LilyGO TTGO T8 ESP32-S2 - 1.14 inch TFT Display" ( https://www.tinytronics.nl/shop/nl/deve ... ft-display )
When I first powered it, I was amazed by the reaction of the board. It shows a rainbow "LilyGo" logo and looks for an SD card to mount, but because there isn't one connected, the ESP goes to deepsleep.
This is more then I ever will get Flowcode do with this board (because of my limited skills/imagination) :-)
This board seems promising :-)
Does anyone uses this one? Can I please have some examples to get me starting?
I'm looking for examples that I use to chop things into pieces which I can reuse in later projects.
So if anyone ever made something with this board, and is willing to send me the project with some explanation, this will be gratefully accepted! :-)
Has thanked: 698 times
Been thanked: 768 times
Re: Looking for examples: LilyGO TTGO T-Display ESP32
Hi.
I don't have the same TTGO as you, hence keeping the project basic.
I have put together a basic seconds counter to get you started
The simulation will be much quicker than the hardware.
TTGO Display Test1 .fcfx
(15.2 KiB) Downloaded 540 times
MJU20
Post by MJU20 »
Thank you Martin!!
But as always things don't work like they should at first attempt..
When trying to upload the flowchart to the board I get error messages..
What I already tried was to use a USB cable that I use for other projects.
Press the "BOT" button on the board when connecting.
Tested the COM port and the baudrate (can read it with a serial monitor at 115200baud)
Then I tried to find some Arduino sketches that use the TFT display but when compiling the message says: "this is a ESP32-S2" chip".
Flowcode shows these compiling messages:
Chip is unknown ESP32 (revision 0)
Features: WiFi, BT, Single Core, Embedded Flash, VRef calibration in efuse, Coding Scheme 3/4
WARNING: Detected crystal freq 344.33MHz is quite different to normalized freq 40MHz. Unsupported crystal in use?
Crystal is 40MHz
MAC: 0b:ad:ba:d0:0b:ad
Uploading stub...
Running stub...
A fatal error occurred: Invalid head of packet (0x50)
Adding "flash"'s dependency "all" to list of commands with default set of options.
Running ninja in directory d:\ttgo_display_test1_\build
Executing "ninja all"...
Executing action: flash
Running esptool.py in directory d:\ttgo_display_test1_\build
Executing "C:\espressif\tools\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\espressif\esp-idf\components/esptool_py/esptool/esptool.py -p COM9 -b 115200 --before default_reset --after hard_reset --chip esp32 write_flash @flash_project_args"...
esptool.py failed with exit code 2
Programming Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_prog.bat reported error code 0x1
Autoclose turned off
Could this be because Flowcode doesn't know the ESP32-S2 chip?
Any support on this one?
Sorry, it looks like the ESP S2 is not yet supported.
Ben has just ordered one and it should be with him next week.
As this is a third-party toolchain, we have no control over it, but hopefully, we can get it to work with S2-type devices.
Would you like the details of my TTGO?
Has thanked: 222 times
Been thanked: 240 times
Hi Martin
Yes a link to your TTGO type would help.
If you can take a look with Ben at my post.
There is also an ESP32 not yet available.
Thank you
ESP32 Ultra­Low­Power RISC­V Single­Core CPU
https://flowcode.co.uk/forums/viewtopic.php?f=4&t=1318
Hi.
This is the one I ordered.
It works really well.
Like everything prices have gone up a lot.
I paid £9.81 for the 16M version.
With searching, you could probably get them cheaper.
MJU20
Post by MJU20 »
Ok, thanks guys.
I will wait until the ESP32-S2 is supported!
MJU20
Post by MJU20 »
Any news on support for the ESP32-S2 ? :-(
