Esp
WingNut
Has thanked: 45 times
Been thanked: 31 times
Esp
Post by WingNut »
So, I've started dabbling with esp32 devices. Total esp noob. :)
Just installed toolchain and tried my first compile. Got the error in the message file but I haven't the slightest notion what it means. Quick pointer to get me moving along would be appreciated (Martin me old mucker?)
N
ESP32 temp monitor.msg.txt
(2.71 KiB) Downloaded 375 times
ESP32 temp monitor.fcfx
(14.7 KiB) Downloaded 500 times
Has thanked: 663 times
Been thanked: 739 times
Re: Esp
Did you follow this to the letter making sure the IDF version is 4.1 that has been installed?
I would recommend uninstalling python, and ESP idf and following the PDF within the link I sent step by step as the ESP32 toolchain is really fussy.
WingNut
Re: Esp
Post by WingNut »
No sorry I accepted the defaults but have reinstalled and now getting python errors i need to resolve
Re: Esp
What python version did you install?
Perhaps if you reinstall again you can manually delete the python and IDF folders after uninstalling them?
WingNut
Re: Esp
Post by WingNut »
3.74
That ok?
Re: Esp
3.74 should be OK to install.
WingNut
Re: Esp
Post by WingNut »
Hi Martin whats the output file called? I think I have it compiling ok
(15.93 KiB) Downloaded 457 times
