ESP32 failed to compile to hex
RGV250
Has thanked: 46 times
Been thanked: 46 times
Flowcode v10 ESP32 failed to compile to hex
Post by RGV250 »
I have downloaded the app developer power monitor, I installed the ESP32 toolchain and tried to compile. As I did not have the device conected I tried the compile to hex option. It said "Done!" so I thought everything had been installed correctly but it then carried on and I got an error. I then tried compile to C and that gave a message saying that it had been compiled successfully.
I wondered if this is just an issue with compile to hex which I will probably never use, I will try tomorrow when I find the actual ESP device.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
Running cmake in directory C:\BG_WORK\Flowcode\PowerMonitor\Mains_PMon_v1.0-ESP32_Wroom_Firmware\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 C:\BG_WORK\Flowcode\PowerMonitor\Mains_PMon_v1.0-ESP32_Wroom_Firmware"...
ERROR: C:\Users\Admin\.espressif\python_env\idf5.0_py3.7_env\Scripts\python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument.
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
Bob
Has thanked: 717 times
Been thanked: 777 times
Re: ESP32 failed to compile to hex
Hi Bob.
Take a look at this post.
RGV250
Post by RGV250 »
That post fixed it.
Bob
