I am trying to add a state machine to an existing Web App. The addition of a State Machine macro causes the Web App to no longer function even though the added State Machine is not called/executed. The page will load and the buttons and switches will toggle but the previously working flow chart macros no longer execute. I also tried calling the macro from a timer with the same result.
best regards,
jj
State Machine Breaks working Web App
CactCat
- Been thanked: 1 time
- Has thanked: 297 times
- Been thanked: 459 times
Re: State Machine Breaks working Web App
Thanks for pointing this out. To confirm - Web Developer does not support the use of State Diagrams. I will change Flowcode so that State Diagrams are not an option when designing web apps.
Would state machines work in PC App?
If so is there an easy way to make a Web App into a PC app?
State Diagrams work fine in PC Developer apps. But there is no wat to convert between PC and Web Developer apps.
