Timer interval and Timer - problem
LeighM
Has thanked: 73 times
Been thanked: 218 times
Re: Timer interval and Timer - problem
Post by LeighM »
1) Help -> Library Updates
2) Add a Timer component macro to your project
Note: Timer component is not needed for simple Delay icon.
Has thanked: 446 times
Been thanked: 606 times
In both programs you posted you are not calling any of the component macros of the timer component. This as I said is problematic.
As you're not calling any of the component macros that can cause problems in the code generation.
Aha Leigh beat me to it :)
DStoyankov
Been thanked: 1 time
Post by DStoyankov »
Thanks! Only with Timer it worked. After I added a timer interval again error
Flowcode3.msg.txt
(2.93 KiB) Downloaded 211 times
Flowcode3.fcfx
(10.95 KiB) Downloaded 223 times
LeighM
Post by LeighM »
You could do with exploring the Help -> Wiki -> Components search
Then ensure you have set the component properties.
For example, for the TimedInterval component you need to set a callback macro (that runs at the timed interval)
DStoyankov
Thanks! Everything is OK
