V10 after the update no longer simulates!
sonic11
Flowcode v10 V10 after the update no longer simulates!
Post by sonic11 »
Hello!
Before the update the simulation worked perfectly and after the update it doesn't work anymore
I installed it again but it didn't work
Has thanked: 306 times
Been thanked: 471 times
Re: V10 after the update no longer simulates!
Can you please be more specific? Which update and what exactly is not simulating correctly?
If you have a project or example that is not working, please post it and we will investigate.
sonic11
Post by sonic11 »
So I updated the libraries (component update) and after the update the components on the 2d panel no longer work correctly in debug, I have a 4x20 lcd that worked normally until the update, now it displays artifacts!
I can no longer simulate the code I made.
I uninstalled flowcode but to no avail. Even if I install a new copy it behaves the same. For v10 I have the pic 8bit license.
I've just checked the "generic 4x20" LCD in v10 and it seems to work ok for me. Do you have an example file that shows the problem? That would really help us solve this issue for you.
sonic11
Post by sonic11 »
Hello! I tested the file with a version older than V10 and it works ok. The problem is with the debug section in the updated version which worked ok until the update. Give me a link to an older version or tell me how to solve the problem.
Please attach a project file so I can try to replicate the issue you are seeing. That's really the best way to solve this problem.
If you are reluctant to post your project here, then you could perhaps create a small project that shows the error you are seeing. And if that is no good, you can post your project to me in a PM to keep it out of the public domain.
