MCP320x 16-bit to Nano
viktor_aust
Has thanked: 18 times
Been thanked: 5 times
Post by viktor_aust »
Hi all
MCP3201 16-bit to MC format question
After some research I found, that MCP3201 Tx the 16-bit ‘word’.
?,?,0(NULL), B11,B10,B9,B8,B7,,,B6,B5,B4,B3,B2,B1,B0,B1
?,?,0 should be removed and MSB B11,B10,B9,B8,B7 will get an extra zeros (at the end).
LSB-> B6,B5,B4,B3,B2,B1,B0,B1 should loose the last B1.
After 4 bits are removed, only 12-bit ‘word’ should be inside the modified msb+lsb data (8 bit + 8 bit).
Some suggest rx the two bytes, convert them to integer (adc_out_int = (msb << 8) | lsb) and only after that use the bitwise operator to move 3 msb ‘trash’ bits left and one bit right in lsb.
Some suggest to work with bytes:
adc_out_int = msb & 0x1F << 3 | lsb & 0xFE >> 1
OR
adc_out_int = msb & 0x1F << 7 | lsb & 0xFE >> 1 (not sure why 7?)
etc.
Question
SPI Master component allows to Rx the string.
However, with the warning about the NULL problem.
I tried, it does not work.
If I cannot Rx the string, is it possible to receive the characters one by one?
Do I have to use the lsb/msb bytes only?
Thanks.
Has thanked: 173 times
Been thanked: 989 times
Re: MCP320x 16-bit to MC format question
Post by mnfisher »
Looking at the datasheet - this is indeed the case - so as the SPI component reads the data in bytes (8 bits) there will be 4 bits to remove.
There are ways around this:
1) Mask/shift the appropriate bits in the bytes received before conversion to a word.
2) Convert to 16 bit word then mask and shift.
3) Bit-bang the SPI CLK pin and just receive 12 bits (obviously a little harder but the most fun :) )
The string receive doesn't quite do what you want (0 character is EOS (end of string) so I would probably use one of the byte array functions (or 3)
viktor_aust
Thank you Martin.
One more question.
The SPI Master component allows to receive the characters.
But (not like UART) in byte only 'word'.
Can I receive character by character?
viktor_aust
Looks like the spi protocol receive the bytes only:
SPI (Serial Peripheral Interface) receives and transmits bytes (8-bit data), not characters.
Post by mnfisher »
Yes - the SPI does just send and receive bytes (8 bits) - however characters are also just bytes too... Strings - 0 is treated as the end of the string - so receiving a string will 'stop' at this point.
You could use Transaction to receive a byte at a time - just send 0 if no data to send (SPI is bidirectional (or full duplex) - data is clocked out at the same time as it is clocked in) or use TransactionArray()
so:
byte DataOut[2] = {0,0}
byte DataIn[2]
TransactionArray(.DataOut, .DataIn, 2)
.val = (DataIn[0] << 8) + DataIn[1] // assuming MSB LSB order
.val = .val >> 4 // Assuming 4 padding bits
viktor_aust
MCP3201 does not have the Din. Only Dout.
I cannot use the Transaction.
I am thinking to use the CAL SPI, but not sure how to set the parameters (MCP2101 can receive the msb first or lsb first).
I do not have some stable results with the MPC3201 Vin = floating.
Even when I connect the Vin to 5v or to Gnd the results are not stable.
As I understood the lsb is the important data parameter.
I have to check the SPI Master initialisation (something is wrong).
Thanks Martin
Post by mnfisher »
To use the spi - probably use spi master.
To compile you will need to specify a DOUT (MOSI)- it won't be connected to any thing - but this is okay (toggling the clock pin transfers the data). If using transactions - the dataout will be just be dummy data which will be ignored. Note that some MCUs only support transactions - but if using an AVR or PIC you could use either transactions or not.
MISO is connected to DOUT on the adc.
CS to Chip select (if using an Arduino this just be D10 or set d10 to be an output - it defaults to the wrong pin)
Clock to clock
Vcc and gnd
Conversion is initiated by CS going low.
If pins are very tight (none spare for the 'dummy' MOSI) - bit-banging is relatively easy too.
viktor_aust
Appreciate your help Martin
Will do some tests
viktor_aust
Re: MCP320x 16-bit to Nano
Post by mnfisher »
Looks though it's working reasonably....
I've done a version - but haven't been able to test yet.... Just toggles CLK and reads the 12 bits of data...
I think - the loop count might need changing - I have 15 (2 undefined, 1 null and 12 data)
mcp3201.fcfx
(12.91 KiB) Downloaded 76 times
