Dashboard Panel
The Dashboard Panel provides a framework on which to load Flowcode components that compliments the System Panel. It is designed to show the representation of abstract components such as dials and meters during simulation.
The Dashboard Panel
Overview
The Dashboard Panel is opened by selecting it in the View menu. When it opens, you see a colored workspace. The color is set in the General Options.
Error creating thumbnail: Unable to save thumbnail to destination
Unlike the System Panel, the Dashboard panel gives only a top-down view of the components, though they can be made more lifelike by clicking on the ‘3D view’ icon.
Differences to the System panel
The Dashboard panel has a Shapes toolbar running vertically down the left-hand side, and a Controls toolbar running horizontally across the top. However these have more limited functionality on the System panel as the Dashboard is not designed for modelling objects or creating components.
Camera control
  • Hold down the Ctrl key and click-drag the mouse to pan the camera.
  • Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Hint:
Selecting items
They can then be grouped:
  • By clicking on the 'Group' icon.
Shapes toolbar
Below it is the 'Text' icon, used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, you can edit the default text displayed using the bottom ‘Text’ control on the Properties Panel.
The next icon is a 'Textbox' icon. Unlike the text label this has multiple lines and the text does not stretch as its area is resized.
The remaining icons allow you to add a variety of shapes, all two-dimensional, to the work area. Each takes the colour chosen in the colour selector at the top. Each one can be configured using the Properties Panel, to determine the position, size and rotation of the shape, for example.
If 3D shapes are required any object can be dragged between the Dashboard and System panel and dropped in the required position.
Controls toolbar
Moving objects
Component controls
The left-hand end control allows you to move the selected object around the work area.
Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Gen Panel Object Resize 01.png The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
General Options
The first option move through ignores collision by moving through the colliding object and ignoring it completely.
The default middle option move around avoids collision by moving the object around the colliding object.
The last option move over avoids collision by moving the object over the colliding object.
The first allows you to lock movement of objects:
  • To the grid,
  • To other objects,
  • To the table-top
The grid can be re-sized and made visible in a range of colours via this control.
The second is used to:
  • Set the colour or image of the display;
  • Set the level of detail of all the displays.
