System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options.
Table top
Camera control
- Camera controls
- Hold down the Ctrl key and click-drag the mouse to move the camera eye.
 - Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
 - Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Zoom
Axis alignment
Hint:
Selecting items
They can then be grouped:
Shapes toolbar
Controls toolbar
Moving objects
 The left-hand end control allows you to move the selected object around the work area.
 Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Gen Panel Object Resize 01.png The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Controlling the camera
 The first allows the  camera to pan left / right / up / down.
 The second allows the camera to rotate assuming the table top is the ground.
 The third allows the camera to rotate without considering the table top.
General Options
 The first option move through ignores collision by moving through the colliding object and ignoring it completely.
 The default middle option move around avoids collision by moving the object around the colliding object.
 The last option move over avoids collision by moving the object over the colliding object.
 The next control is used to align the camera axis with the selected object.
 The first allows you to lock movement of objects:
- To the grid,
 - To other objects,
 - To the table-top
The second general options dialog is used to:
Multiple views
By selecting multiple views in the 'General Options' several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
