GLCD
Types of graphical display
Monochrome
These displays are typically arrays of pixels that can be either switched on or off.
They tend to be fast to refresh and low cost but are limited in terms of what they can display.
Colour
These displays are typically arrays of pixels that have associated red, green and blue colour channels. Each colour channel will have a bit depth that dictates what resolution is available for that colour. A common colour bit depth is 565 where the red and blue colour channels have 5 bits (0-31) and the green colour channel has 6 bits (0-63), making a total of 16-bits that are easily transferred using two standard 8-bit byte transfers.
The GLCD component is aware of the colour depth of the display and will automatically convert and scale the assigned RGB colour byte (0-255) to the correct bit depth.
They tend to be slower to refresh due to the increased data per pixel and slightly higher cost but can display full colour images.
Serial
Serial displays have a pin for clock and a pin for data in. The data is transferred a single bit at a time by placing the data onto the data pin and then strobing the clock pin.
These types of display consume less pins of the host microcontroller but tend to be slower as you have to individually clock in each bit.
Often these types of display can be used with an SPI peripheral to help speed up the data flow into the display. This is because the SPI peripheral can often output data much faster then simple pin toggling.
On some microcontrollers the SPI can run much faster if you can give it a burst of data rather then byte by byte. For larger displays there are properties named Queue Fast Pixels and when enabled you can set how many pixels will be buffered and transferred in a single chunk.
Parallel
Parallel displays often have a number of data pins up to 8 or 16 and a single clock pin. The data is transferred in multiple bits at a time by placing the data onto the data pins and then strobing the clock pin.
Ideally when using parallel displays you would assign the data pins to a port of the microcontroller which then allows you to write to all the data pins in a single operation, significantly increasing the speed of sending data to the display.
The downside to this is you require a lot more connections to the host microcontroller.
Other Control Pins
RS / CD / RE / A0
This pin can have several names register select (RS), command data (CD), register enable (RE), Address0 (A0). They all do the same thing and simply tell the display if you are transferring a register address or a data value.
CS / CE
The chip Select (CS) or chip enable (CE) pin is there to tell the display if you are talking to it. It is common practise to tie this to ground if the display is always enabled.
For systems where the display is on a shared SPI bus it is a requirement to use the CS pin to control when you are communicating to the display and when you are communicating with other equipment.
The display component properties let you determine if CS pin is used and if it is actively toggled.
UseCS = No - don't do anything with the CS pin, user must connect the display CS pin to Ground or manually control it themselves using output icons.
UseCS = Yes - ToggleCS = No - Pull the CS pin low during the component initialise (enabled) and then don't do anything else with the pin. Allows future flexibility but avoids slowdown due to no instructions for toggling the CS pin.
UseCS = Yes - ToggleCS = Yes - Pull the CS pin high during the component initialise (disabled) then automatically toggle the pin to enabled when communicating with the display before toggling back to disabled.
Reset
The reset pin is used to reset the display back to a known condition, essentially resetting all the registers back to factory default.
The reset pin can also help with noise on the clock pin before the display has been initialised.
The reset pin is automatically strobed during initialisation and then held high.
If you do not wish to connect the reset pin to the microcontroller then you can simply connect it to the VCC power rail and then change the UseReset property to No. If you're not using the reset pin then it is wise to add a pull up or pull down resistor on the clock pin to avoid the pin floating during startup.
Core Functions
Colours
Foreground colour
Property that set the colour for all foreground pixels. E.g. Fonts shapes etc.
Background colour
Plot
Draws a single pixel at the provided coordinates in the foreground colour.
BPlot
Draws a single pixel at the provided coordinates in the background colour.
Draw Line
Draw Rectangle
Additional Libraries
Images
Graphs
Touch
Management
Custom Fonts
There are up to four different fonts packaged and used by the display for printing strings of characters. Each of these four fonts can be selected from a predefined drop down list.
If you wish to use a specific font that is not already included then you can use a custom font as detailed here.
gLCD Font Library
Changing the display
If you want to replace the display in one of the examples with a different display type then information on how to do this can be found on the Replacing a Component page.
