Camera Control
The Panel Camera controls can only be found on the System Panel as it is the only 3D environment and therefore needs extended navigation options instead of just the 'Pan'
camera control which the Dashboard Panel is bound to as it is a 2D environment.
- Hold down the Ctrl key and click-drag the mouse to move the camera eye.
- Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
- Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Zoom
Axis alignment
File:Gen Panel Camera Axis Align.png You can use the Align Axis button to lock or rather mirror the axis to the selected object, this follows the axis of the component even when being manipulated and rotated.
Hint:
