Camera Control
Revision as of 15:06, 20 August 2013 by BenR (talk | contribs)
The Panel Camera controls can only be found on the System Panel as it is the only 3D environment and therefore needs extended navigation options instead of just the 'Pan' camera control which the Dashboard Panel is bound to as it is a 2D environment.
Pan allows the camera to pan left / right / up / down.
Rotate allows the camera to rotate assuming the table top is the ground.
Orbit allows the camera to rotate without considering the table top.
  • Hold down the Ctrl key and click-drag the mouse to move the camera eye.
  • Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
  • Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Video instructions Camera Control 1 Camera Control 2
Zoom
Axis alignment
You can use the 'Align Axis' button to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated.
Hint:
