Camera Control
<sidebar>Sidebar: Getting Started</sidebar>
The Panel Camera controls can only be found on the System Panel as it is the only 3D environment and therefore needs extended navigation options instead of just the 'Pan'
camera control which the Dashboard Panel is bound to as it is a 2D environment.
- Hold down the Ctrl key and click-drag the mouse to move the camera eye.
- Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
- Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Video instructions
See the following Youtube videos to learn how to effectively control the camera and navigate the panels.
| CERJCvyInV8}} | uG20xwQtcCM}} |
Zoom
Axis alignment
You can use the 'Align Axis' button to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated.
Hint:
