System Panel
The System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options.
Table top
Video instructions
There are an array of videos at your disposal to educate you and improve your skills using Flowcode, to get started with the System Panel see the Introduction to the System Panel video for an overview of the fundamental functionality available using the System Panel.
{{#ev:youtube|2VvUSCCc-sE|640}}
Camera control
  • Hold down the Ctrl key and click-drag the mouse to move the camera eye (the position of the camera).
  • Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target (the view of the camera).
  • Hold down Alt and click anywhere on the panel to move the camera over that point or object (move the camera to the object).
Zoom
Axis alignment
Hint:
Video instructions
See the following Youtube videos to learn how to effectively control the camera and navigate the panels:
The Camera Control 1 video covers the basic camera controls and camera rotation and general camera manipulation.
The Camera Control 2 video covers slightly more advanced features such as using keyboard shortcuts as well as mouse movement to navigate the panel more effectively.
CERJCvyInV8}} uG20xwQtcCM}}
Manipulating objects
Selecting items
They can then be grouped:
  • By clicking on the 'Group' icon.
Shapes toolbar
Video instructions
Watch the Adding Objects to the Panel video for a demonstration and explanation about adding components and objects to the System Panel.
See the Aligning Objects on the Panel 1 video to learn the basics of aligning objects on the panel, this video covers the all available options of the 'Snap to' function including Snap to Grid, Objects and Table top.
The next video, Aligning Objects on the Panel 2, expands onto manipulating objects by moving, rotating and scaling / re-sizing objects to align them on the panel, this video makes use of the Project Explorer in order to manipulate the objects precisely.
Finally, the Alignig Objects on the Panel 3 video details additional options to effectively align objects on the panel, this includes various options from the context menu when you right-click a selected object.
2yT5XTLLX6o}} 5-IzDJ2NDcc}}
okbJ9pJrEeA}} 0b0jtQzBS9Q}}
Controls toolbar
Moving objects
Component controls
Move allows you to move the selected object around the work area.
Stretch allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
Scale allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Rotate allows you to rotate an object. After selecting it and clicking on this control, a number of yellow anchors appear on the object. These allow the object to be rotated around different axes. Corner anchors will spin the object.
Controlling the camera
Camera controls
Pan allows the camera to pan left / right / up / down.
Rotate allows the camera to rotate assuming the table top is the ground.
Orbit third allows the camera to rotate without considering the table top.
General Options
Move Through ignores collision by moving through the object and ignoring collision completely.
Move Around avoids collision by moving the object around the colliding object. Note: this is the default option set by Flowcode.
Move Over avoids collision by moving the object over the colliding object.
The Align Axis control is used to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated
The first control, 'Tools' allows you to lock movement of objects:
  • To the grid,
  • To other objects,
  • To the table-top
The second control, 'General Options' is used to:
  • Set the colour or image of the display;
  • Set the number of views, allowing, for example, plan and elevation views of a component;
  • Set the level of detail of all the displays.
Multiple views
By selecting multiple views in the 'General Options' several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
A powerful feature of Flowcode 6 is the ability to view the components from a number of different directions simultaneously.
  • To see this:
Click on the 'General options' icon.
In 'Number of views:', click on the down-arrow and select "3".
By clicking on the appropriate arrowheads, set up each view as shown below.
(Depending on the size and shape of the Systems Panel, the three views may be arranged vertically, instead of horizontally.
Drag one edge of the Systems Panel sideways to see this effect. )
An example of doing so is given below - notice the positions of the red, green and blue arrows in each:
In the next image, the instrument panel has been rotated:
