API Panel.LinkBar
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Position linkage management
This class is contained within Panel.
Functions provided for this class
Create Creates a new bar linking a pair of position handles
SetVisible Sets whether the link is displayed or not
SetStartPos Sets the position for the start point of the bar
SetEndPos Sets the position for the end point of the bar
SetStartAdjustment Sets the clipping adjustments for the beginning of the link
SetEndAdjustment Sets the clipping adjustments for the end of the link
SetStartGfx Sets the graphic for the start point of the bar
SetBarGfx Sets the graphic for the main line of the bar
SetEndGfx Sets the graphic for the end point of the bar
GetStartPos Gets the position the bars start point is located at
GetBarPos Gets the position the bar is located at
GetEndPos Gets the position the bars end point is located at
Update Manually refresh the screen the point cloud exists on
EnableAuto Sets whether Flowcode should automatically draw links for component object property types
Constants provided for this class
Used by SetStartGfx(), SetEndGfx()
Type Name Value Description
LONG Cap_None 0 No cap is drawn for the start or end point
LONG Cap_Line 1 A line arrow is drawn
LONG Cap_Triangle 2 A flat 2D traingle
LONG Cap_Cone 3 A 3D cone
LONG Cap_Sphere 4 A 3D sphere
LONG Cap_Dome 5 A 3D half-sphere
LONG Cap_Cylinder 6 A 3D cylinder
Used by SetBarGfx()
LONG Bar_None 0 No bar is drawn between the start and end points
LONG Bar_Line 1 A line is drawn connecting the start and end
LONG Bar_Cone 2 A 3D cone is drawn connecting the start and end points
LONG Bar_Cylinder 3 A cylinder is drawn connecting the start and end points
Used by SetStartAdjustment(), SetEndAdjustment()
LONG Adjust_None 0 The point will meet the center of the target position
LONG Adjust_Sphere 1 The point will meet the edge of the sphere encompassing the position
LONG Adjust_Box 2 The point will meet the bounding box of the sphere
See also
