Camera Control
<sidebar>Sidebar: Flowcode Help Overview:Panels</sidebar>
There are two methods in which you can interact with the simulation panel; Camera and Cursor mode. It is a dynamic menu, and selecting the ‘Arrow’ icon
will change the functionality of the three icons to its right.
Camera Mode You can pan (1), rotate (2) and zoom (3) the camera. To pan and rotate, hold the left mouse button and drag. To zoom, drag a box to the required size or use the mouse wheel to zoom in/ out.
Cursor Mode
Cursor Mode allows you to move (1), rotate (2) and scale (3) objects. When a shape is selected in cursor mode you will notice a set of ‘local’ axes appear on your shape. To ‘free move’ the object in the panel, left click and hold the object and drag. Alternatively, if you want to move your object along a constrained axis, left mouse click on these local axes and drag. Note; rotate and scale work in a similar way.
- Interaction Methods
Camera Mode
Cursor Mode
The Panel Camera controls can only be found on the System Panel as it is the only 3D environment and therefore needs extended navigation options instead of just the 'Pan'
camera control which the Dashboard Panel is bound to as it is a 2D environment.
- Hold down the Ctrl key and click-drag the mouse to move the camera eye (the position of the camera).
- Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target (the view of the camera).
- Hold down Alt and click anywhere on the panel to move the camera over that point or object (move the camera to the object).
Zoom
Axis alignment
You can use the 'Align Axis' button to mirror the axis of the selected object, this follows the alignment of the component axis, even when being manipulated and rotated.
Hint:
Video instructions
See the following Youtube videos to learn how to effectively control the camera and navigate the panels:
The Camera Control 1 video covers the basic camera controls and camera rotation and general camera manipulation.
The Camera Control 2 video covers slightly more advanced features such as using keyboard shortcuts as well as mouse movement to navigate the panel more effectively.
| CERJCvyInV8}} | uG20xwQtcCM}} |
