Compiler Toolchains
Revision as of 14:04, 9 October 2020 by BenR (talk | contribs)
Compiler Toolchain
The compiler toolchain is used to allow Flowcode to compile the generated C code into a binary file that can be executed on your target microcontroller device.
The "Compile to Hex" and "Compile to Target" options in Flowcode require that a toolchain is installed for your selected microcontroller device.
Downloading and installing toolchain
Most of the toolchains can be found here on the main Flowcode download page.
Download and run the toolchain installation file and that will do everything required to allow Flowcode to compile to that range of target devices.
Note if you have Flowcode open when installing the toolchain then you may need to restart Flowcode once the toolchain is installed.
ESP32 Toolchain
The ESP32 toolchain includes a lot more extras and so we have used the standard Espresif installer as that does all the extra functionality for you.
The only downside to this is you have to manually point Flowcode at the toolchain.
The toolchain can be downloaded from here: Espressif ESP32 IDF Toolchain
When installing you need to include Python, Git and the Espressif IDF as part of the installation process. These are all required by the end toolchain to compile and program ESP32 devices.
Once you have installed make a note of where you installed the toolchain.
In Flowcode click on View -> Global Settings -> Locations Tab
Set the path for the ESP toolchain by pasting in the installed toolchain location. By default this is C:\Users\Username\.espressif
