Dashboard Panel
The Dashboard Panel provides a framework on which to load Flowcode components that compliments the System Panel. It is designed to show the representation of abstract components such as dials and meters during simulation.
The Dashboard Panel
Overview
File:Gen opt icon.jpg The Dashboard Panel is opened by selecting it in the View menu. When it opens, you see a colored workspace. The color is set in the General Options.
Unlike the System Panel, the Dashboard panel gives only a top-down view of the components, though they can be made more lifelike by clicking on the ‘3D view’ icon (File:Panel Icon Perspective.jpg).
Differences to the System panel
The Dashboard panel has a Shapes toolbar running vertically down the left-hand side, and a Controls toolbar running horizontally across the top. However these have more limited functionality on the System panel as the Dashboard is not designed for modelling objects or creating components.
Camera control
  • Hold down the control key and click-drag the mouse to pan the camera.
  • Hold down alt and click anywhere on the panel to move the camera over that point or object.
File:Panel Icon Zoom.jpg There is also a zoom facility, operated by pressing the Ctrl key and moving the cursor over the viewpoint icon. Clicking the mouse button in this and dragging downwards causes the view to zoom out. Dragging upwards causes the view to zoom in. The same functionality can be achieved by holding Ctrl and using the mouse wheel.
Hint:
Selecting items
  • By holding down the shift key and then clicking on a number of items, one after the other;
They can then be grouped:
  • By clicking on the group icon (File:Panel Icon Group.jpg).
  • By selecting the ‘Group’ option from the ‘Selection’ menu which appears when you click the right-hand mouse button.
Shapes toolbar
File:Panel Toolbar Shapes3D.png
Below it is the text icon, used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, you can edit the default text displayed using the bottom ‘Text’ control on the Properties Panel.
The next icon is a text-box icon. Unlike the text label this has multiple lines and the text does not stretch as its area is resized.
The remaining icons allow you to add a variety of shapes, all two-dimensional, to the work area. Each takes the colour chosen in the colour selector at the top. Each one can be configured using the Properties Panel, to determine the position, size and rotation of the shape, for example.
If 3D shapes are required any object can be dragged between the Dashboard and System panel and dropped in the required position.
Controls toolbar
Moving objects
File:Panel Toolbar Control.jpg
Component controls
File:Panel Icon Move.jpg The left-hand end control allows you to move the selected object around the work area.
File:Panel Icon Stretch.jpg Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Panel Icon Resize.jpg The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
File:Panel Icon Rotate.jpg
General Options
File:Panel Icon Collision.jpg The next control determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other, with respect to the camera view.
File:Panel Icon Tools.jpg The first allows you to lock movement of objects:
  • To the grid,
  • To other objects,
  • To the table-top
File:Panel Icon GeneralOpts.jpg The second is used to:
  • Set the colour or image of the display;
  • Set the level of detail of all the displays.
