Compiler Toolchains
Revision as of 12:57, 10 July 2026 by SteveT (talk | contribs)
Compiler Toolchain
The compiler toolchain is used to allow Flowcode to compile the generated C code into a binary file that can be executed on your target microcontroller device.
The "Compile to Hex" and "Compile to Target" options in Flowcode require that a toolchain is installed for your selected microcontroller device.
Downloading and installing toolchain
Most of the toolchains can be found here on the main Flowcode download page.
Download and run the toolchain installation file and that will do everything required to allow Flowcode to compile to that range of target devices.
Note if you have Flowcode open when installing the toolchain then you may need to restart Flowcode once the toolchain is installed.
Video
See this video for more help on installing an appropriate toolchain.
Instructions for specific toolchains
Click the approriate link below ofr detailed instructions for spacific compiler toolchains.
ESP32 Toolchain
Pico Toolchain
Using a new version of XC8
