Component: GLCD (ILI9488) (Graphical Color)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 23.0
Category Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Version information
20, 20.0, 02-08-24, MW, Added an aditional font count of 4, total font count of 8
23, 23.0, 28-11-24, MW, Fixed error trap for lines when y = 0
23, 23.0, 28-11-24, MW, Fixed shapes colour background  not working
23, 23.0, 29-11-24, MW, Fixed initial background colour not working
 24, 23.0, 18-03-26, BR, Added DrawBezier function
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
LCD_Write_Data8
LCD_Write_Data8
- BYTE data
LCD_Write_Reg
LCD_Write_Reg
- BYTE data
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetExternalFont
SetExternalFont
Allows one of the default external font files to be switched out for a different font file.
- BYTE FontIndex
Range: 0 to (FontCount - 1)
- STRING Filename
New font filename
- BYTE CharacterSpacing
Number of pixel columns to use between each character
- BYTE SpaceWidth
Number of pixel columns to use for a space character
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Flip X
Flips the horizontal display axis in hardware.
Flip Y
Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Write (WR)
Read (RD)
Use CS
Determines if ther CS pin is used or is connected to ground and always enabled
Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
Chip select pin connection
Reg Select (D/C)
Use Ports
Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Data[7:0]
Use Reset
Determines if the reset pin is used or if it is simply connected to VCC
Reset
Reset pin connection
Use Backlight Pin
LED
Fonts
Font Count
External Fonts
Defines how fonts are stored when compiled to a microcontroller. No - Font data is stored in the microcontroller ROM. Yes - Font data is stored externally on a file source such as an SD card.
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Component Label
Component Label Scale
Physical Orientation
Export Binary Fonts
Allows all selected fonts to be exported as a binary format that can be loaded from an SD card. When set to yes loops through all selected fonts and outputs .bin files into the project directory. May take some time to complete, resets back to no when complete.
Please click here to download the component source project: FC_Comp_Source_GLCD_ILI9488.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ILI9488.fcfx
