Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images ## Resistors ## Capacitors ## Inductors ## Switches ## Indicators and Transducers * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Resistors<^< Passive Component Images | Course Index | Capacitors >^>(:nl:) >>frame round<< This selection of carbon and metal film resistors have power ratings from 0.1Ω (the smallest resistor) to 2Ω (the largest resistor). Resistors of this type are used in a wide variety of 'general purpose' applications. Values range from 1Ω to 10MΩ. >>frame round<< This glazed enamel coated wirewound resistor is rated at 2.5W. Resistors of this type are used in applications where an appreciable power must be dissipated. Values range from 0.1Ω to 10kΩ. >>frame round<< This wire ended ceramic cased wirewound resistor is designed to dissipate an appreciable power. Typical ratings for these types of resistor range from 3W to 15W. Values range from 0.1Ω to 22kΩ. >>frame round<< Aluminium clad wirewound resistors are capable of dissipating very high power levels - typically up to 25W when mounted on a substantial metal heatsink. Values range from around 1Ω to 100Ω. >>frame round<< This ceramic tubular wirewound resistor is rated at 20W and is 'tapped' in order to provide two series connected resistor sections: one of 250Ω and one of 300Ω. Values range from 10Ω to 10kΩ. >>frame round<< This horizontally mounted preset potentiometer is rated at 0.15W. Values range from 100Ω to 1MΩ. >>frame round<< This variable resistor is rated at 0.2W and is fitted with a standard 0.25" diameter control shaft. Values range from 1kΩ to 1MΩ with either linear or semi-logarithmic laws (the latter are commonly used for volume controls with potentiometers of 10kΩ or 100kΩ). >>frame round<< This multi-turn variable potentiometer provides fine adjustment with 10 turns of the potentiometer shaft required to cover the full range of resistance. Values of typically 1kΩ, 10kΩ or 100kΩ are available (linear law only). >>frame round<< This picture shows three typical multi-turn preset potentiometers. Vertical or horizontal types are available (with 10, 18 or 22 turn mechanisms) in values ranging from 1kΩ to 1MΩ. >>frame round<< This potentiometer, designed for service as a volume control, is also fitted with a double-pole, double-throw on/off switch. Values range from 4.7kΩ to 1MΩ with linear or semi-logarithmic laws. >>frame round<< Dual-gang potentiometers are often used in stereo equipment where it is necessary to make simultaneous adjustments to the 'left' and 'right' channels. Values range from 4.7kΩ to 1MΩ with linear or semi-logarithmic laws.
Page last modified on July 26, 2011, at 08:32 AM
