Hello Ben,
I am having issue to get going with the new DSP PI and PID component (used it many times in V7 and V8)
I have two digital values Setspeed and Actual Speed which is my Set and Feed back signals ( as they come over CAN they are numerical values in RPM)
I connect these two values to the PI Component by a Digital Input icon as below however my issue is how to extract the output from the PI component
I use the Process(macro) but I do not see any way to get the value, I also try to use a Digital output but I cannot connect the Digital output to the PI Components.
What am I doing wrong or do not understand Please help as always it isappreciated
my Fc chart trying to get it going
DSP PI Controller
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
- Has thanked: 151 times
- Been thanked: 173 times
Re: DSP PI Controller
Hi Peter
You have done nothing wrong.
Look here, I think Ben will fix it soon
viewtopic.php?f=5&t=777
Greetings from snowy Switzerland
- Has thanked: 449 times
- Been thanked: 609 times
Sorry about this, hopefully solved for you now.
Thanks a lot.
Can you have a look to this program, I testet all and maybe there are few more to fix
Thanks a lot.
- p.erasmus
Ben.
Thanks a million the fix work for my situation however Stefan is corrcet there are a couple more that the Digital output cannotconnect too
Aha excellent thanks for that they all work here but I delayed pushing them out to the update system to confirm everything was ok and now they are no longer flagged as needing pushing.
I'll get these pushed out for you now.
