Hi,Hello everybody.
I'm making this post because I noticed that interrupts don't work with the ESP32.
I downloaded the latest FC10 patch xxxx , but nothing helped.
Regards.
Interrupts ESP32.
djebirmalik
- Has thanked: 1 time
- Been thanked: 1 time
- Has thanked: 161 times
- Been thanked: 950 times
Re: Interrupts ESP32.
What do you mean by 'doesn't work' - for example if the pin is connected to a switch you might get several interrupts due to bounce..
Also worth checking (using a terminal program - such as PuTTY) that the esp32 isn't spitting out some info.
djebirmalik
djebirmalik
It doesn't seem to work in sim - which is odd as you'd imagine the simulation engine was the same as other targets (it does work, for example on AVR)
- Has thanked: 289 times
- Been thanked: 453 times
I think the error can be fixed with a library update for the target device. We should have a new one for you soon.
djebirmalik
- Has thanked: 615 times
- Been thanked: 807 times
Hopefully fixed for you now.
