Is the ESP32 able to perform accurate trigonometry functions with FC10? I'm trying to use some ordinary cosine and sine functions, but I'm getting strange results.
Could there be something in the FC10 documentation (Wiki) that states if it uses radians instead of degrees?
Trigonometry functions for ESP32
MJU20
- Has thanked: 105 times
- Been thanked: 76 times
- Has thanked: 627 times
- Been thanked: 833 times
Re: Trigonometry functions for ESP32
Cos and Sin programming functions will generally always use radians rather then degrees. Hope this helps. If you like you can convert your degrees to radians by multiplying by 0.0174533.
If it's still being strange then let us know and I'll investigate.
Yes I've done that for you now, let me know if this is ok.
https://www.flowcode.co.uk/wiki/index.p ... _Functions
