hello
I am really disappointed, I thought I could program esp32 with Flowcode, but it has been at least 10 times since I uninstall and reinstall esp-idf, git and python without success. I tried with python 3.7, 3.8, 3.9. with esp-idf 2.3 and 2.4. by scrupulously following the installation pdf recommended on the forum. But nothing works. When the installation takes place without error 1 or error 2. It is during compilation that I have an error. Is there a foolproof method?
Thank you
cordially
Francois
Esp-idf Installation
muller54
LeighM
- Has thanked: 105 times
- Been thanked: 302 times
Re: Esp-idf Installation
Unfortunately not with Windows.Is there a foolproof method?
Common problems are such as spaces or non simple alpha characters in paths.
Best also to go with the suggested defaults of the Espressif installer.
Could you post the project msg.txt file? This will/might helps us identify the error.
Thank you for your reply. I enclose the message from the compiler
- Compiler Messages.txt
- (3.32 KiB) Downloaded 696 times
- Has thanked: 626 times
- Been thanked: 833 times
Did you use your own version of python? It looks like python is missing libraries. Click, pyserial etc.
