Just purchased the RPI/PICO component bundle and did a quick LED flash test using the RPI 4B.
Simulation is fine. Build to HEX compile fails immediately.
RPI_CAL_String.c fail
Don't think the problem is my toolchain. Could someone quickly check.
All the files are attached in the zip.
Charles
RPI 4B Flashing LED Test Compile Fail
- canary_wharfe
- Has thanked: 15 times
- Been thanked: 16 times
- RPI 4B Flashing LED Test Compile File.zip
- (5.55 KiB) Downloaded 231 times
< The Flowcode 11 Pro Silicon Chipper >
LeighM
- Has thanked: 109 times
- Been thanked: 302 times
Re: RPI 4B Flashing LED Test Compile Fail
I've not had chance to check your zip yet.
But have you tried a full database update?
The CAL string files have had some changes recently.
- canary_wharfe
Yes I just did a full update and the compilation error is still there unfortunately.
- Has thanked: 637 times
- Been thanked: 847 times
- canary_wharfe
Yes, all working now. Thanks Ben.
